NI TestStand
How to access a dll
HI,
I"m using TS3.5
I'm given a dll file, lib file and many h files and a sample test in c file. (no source files for the dll)
I was able to run this c file under Labwindows/CVI, link it and run it ok.  (The file creats a TCP/IP link and run a test on SmartBits equiptment.)
Now, I'm wishing to run the same functions executed in CVI from TestStand.
I created an Action step using the  c/c++ dll adaptor.  In the 'specify module' window, I specified the dll and selected the function.
I get   'This function either does not have parameter information in the dll or uses types not recognized by TestStand'.
Is there a way out?
I put all the files under one directory.
Thanks and regards
Rafi
(5,348 Views)
Hi Rafi,
Can you not just create a wrapper function that interfaces your dll function to TestStand instead of trying to call the dll function direct from TestStand.
Regards
Ray
Regards
Ray Farmer
(5,336 Views)
Hi Ray,
That's exactly whay I'm doing right now....
However, I thought there's a way to access it directly and wondered how to do it
Rafi
(5,329 Views)
Hi Rafi
Do know the Tool "Dependeny Walker"?   You can download it at http://dependencywalker.com/ . With it you can look "inside" your dll
and maybe find your right parameter definition.
Hope this helps a little bit
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,326 Views)
Would it be possible to post your dll Rafi? I would like to replicate the behavior on my machine.
Nestor
(5,305 Views)
I get these all the time with the DLL's I use.  I assume you know the variables types of the function call.  In that case, after closing the warning box, click on the NEW button next to prototype.  This creates a dummy variable that you will need to match to your function call.  Create as many variables and match them up as necessary, and the function will work.
(5,291 Views)
Although, this thread is a few days old, I like to post my experiance here - maybe it's useful for other users...
The last message is just a workaround (a quite tiring one). The reason is for sure at least 1 type in the function call that is unknown by TestStand. I guess, it's "CAObjHandle". Just replace it by its basetype "int" and it's working. Same on structs and other derived types.
I wonder, how to learn those types to TestStand. I'm quite sure that my example worked before, until it changed with a CVI version update.
If anyone knows, how to declare types to TestStand, please post here.
(5,075 Views)
