NI TestStand
How to access a 'local' variable of a non active sequence
HI,
I'm trying to access a TestStand local variable from TS.  The problem is that the local is in a non active sequence.
For example I have mainSequence and SeqA.  In CVI step I need to access a local variable of seqA.
Is it possible?
I don't like to convert seqA local to FileGlobal as it is widely used at the moment as local.
(2,987 Views)
Hi Rafi,
Try the lookup string of "RunState.SequenceFile.Data.Seq["SeqA"].Locals.MyVariable"
Regards
Ray Farmer
Regards
Ray Farmer
(2,980 Views)
