NI TestStand
How to access scope measurement in TestStand?
I am using TestStand 2020 and Instrument Studio 2020 to read some scope values (MaxValue, PWM). After setting up all scope parameters I can export it directly to TestStand where I see the IO Configuration again.
In TestStand I can "Create a session" and apply my scope settings - this works so far. But, is it now possible to get direct access to my scope measurements I used in the Instrument Studio? Or do I need to built separate and new test with LabView, only to read one of those measurements with TestStand?
Thanks in advance
(1,655 Views)
Hi!
I’m struggling with the same problem. Have you already solved it?
(1,158 Views)
