NI TestStand
How to add a container object in a station global in a vb.net application
Hi Radlou,
That will never work !
You have to pass the 3. Parameter as emtpy string
EXCEPT! you have a named type. If you have created one with type editor you have to enter this name here.
I assume you have not.
All you need is to create 2 container objects and then connect them together with SetPropertyObject
1. Parameter is the Name that will placed in the variables pane.
2. Parameter "PropOption_InsertIfMissing​" if 0 nothing will work !!!
3. Handle to the created object by NewPropertyObject
Or just try this simple example
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 11 of 16
(1,372 Views)
Hi j_dodek
I can't open your example MakeStationContainer_TS40.seq5.Because I don't have the suitable version (4.0) but only the 3.1
Thank you
Message 12 of 16
(1,365 Views)
Here you are
--Signature--
Message 13 of 16
(1,363 Views)
Hi Radlou,
Maybe this example will not work because it uses API expression in statement !
Not sure if this is feature of  4.0 and higher
Regards
Juergen
--Signature--
Message 14 of 16
(1,362 Views)
TestStand API expression were introduced in TestStand 4.0
Therefore you would have to look at each expression that uses an API call and convert it to use the ActiveX Adapter.
Maybe Juergen could do this if there are not too many or at least do one as an example.
Regards
Ray Farmer
Message 15 of 16
(1,347 Views)
Hi Radlou,
Do you still need support ?
Regards
Juergen
--Signature--
Message 16 of 16
(1,339 Views)
