NI TestStand
How to add a menu in Teststand
Teststand provide a way to allow user to add menu item in process model, for example, I can add an "example" item under "configure" menu. However, is there any way to allow user to add menus?.
(3,444 Views)
You add Configure Menu Items by adding 'Configuration Entry Point' sequences to your Process Model.  There are three default 'Configuration Entry Point' sequences in the Sequential Process Model (they are the lighter purple colour)  Configure Report, Database and Model Options.  These will be displayed in the confiure menu when a Sequence file that uses the Sequential Process Model is selected.
You could just copy one of these sequences, in the process model, and modify it for your requirements.
Hope this helps
Steve
There are 10 types of people in the world that understand binary, those that do and those that don't.
(3,437 Views)
You cannot add a new menu.
You can only add items to the Configure menu and to the Tools menu.
Regards
Ray Farmer
Regards
Ray Farmer
(3,432 Views)
