NI TestStand
How to add results to an existing report
Hi, I am using TestStand 3.1 under WinXP with LabWindows CVI 7.1.
I'm trying to run single tests or parts of sequence and generate report that will include the results of all the executions. Please advise how to configure TS to do this.
(2,882 Views)
Hi shimonir,
To generate a report when running just a single or selection of step (i.e In Interactive), you need to use the menu option 'Run Selected Steps Using...' and select either Single Pass or Test UUT's.
This way you execute your selection using a process model and hence result logging.
Where as if you just Run Selected Steps, this executes without the process model and therefore no result logging is done.
Hope this answers your question
Regards
Ray Farmer
Regards
Ray Farmer
(2,878 Views)
