NI TestStand
How to add the rows and columns in a Teststand Custom Report.
    I have a doubt regarding the teststand report format generation. I want to add the extra data in a row or coloumn. Can anyone please help me out with a clear description.
chandrakanth
(3,392 Views)
The easiest way to do this is use the Additional Results step or the Additional Results of the step you want to do.  These three links from the TestStand help will be useful for your situation.  It is important that you understand result collection and then report generation.
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/additional-results-step.html
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/additional-results-dialog-bo...
https://www.ni.com/docs/en-US/bundle/teststand/page/result-collection.html
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,369 Views)
Thanks for your reply. By using the additional result we are able to add the result data but I also required how to add an extra coloumn data like stepID or any other details. please help me out.
chandrakanth
(3,357 Views)
I did not understand that they were both requirements.  I just assumed you wanted one or the other.
If you need an extra column it is unfortunately a lot more work.  What type of report are you generating?  The solution would change depending on the report type.
Most importantly you need to understand 2 things: Result Collection (linked in my previous post) and Report Generation.
Result collection is what collects the data so that when you get to the report generation step you have what you need.
The first step is to understand plugins: https://www.ni.com/docs/en-US/bundle/teststand/page/process-model-plug-in-architecture.html
After you understand plugins then you need to understand how to adjust or modify the specific report type to meet your need.
For example if you are doing XML AND using the horizontal stylesheet then this may be helpful: https://www.ni.com/docs/en-US/bundle/teststand/page/adding-columns-and-rows-to-an-xml-report.html
Some of it may or may not apply to other style sheets.  If you are doing HTML or ASCII then the process will be different.
jigg
CTA, CLA
testeract.com
(3,340 Views)
