NI TestStand
How to add user logins to deployed system
Looking for documentation regarding adding user logins to a deployed system. Also are passwords required for users other than admin?
thanx,
jvh
(3,764 Views)
No passwords are required for any users.
(3,760 Views)
Thanks.
Still need to know how to add more user logins.
(3,750 Views)
The user manager will not be available on a deployed system without the development environment.  Maybe that is the question you are asking?
Here are two solutions:
1.) Setup all users via the User Manager on a development system.  Copy the <TestStand Application Data\cfg\Users.INI file to the deployed system to the same location.  ReStart TestStand.
2.) Create your own custom User Manager.  Much more work, but in the long run a much better solution.
PH
(3,719 Views)
