NI TestStand
How to append 1D array to 2D array (locals)?
I have 1D array of data set and need to store that information to Locals (2D array). Each loop I get 1D array data set and append to the 2D array Locals and at the end of the loop, read the Locals and analyze the data. How can I append 1D array to 2D array Locals variable (directly in TestStand)? Thank you in advance.
(7,900 Views)
Hello, to insert into a 2d array you have to insert one element at a time. You will need another sub loop that runs through each element of the 1d array that you want to insert into your 2d array.
Hope that helps
(7,832 Views)
Or you can try a trick with only one loop 😃 See the attachment.. The recipe is simple:
1. Create Custom data type - Array of ... (type "array" in the example)
2. Create Locals variable of your type "array" - Locals.array1D
3. Create 1D array of elements of type "array" - Locals.array2D
4. Perform a loop for Locals.array2D, on each iteration its current ellement will be defined
5. Access element of a 2D array via Locals.array2D[x][y].. Locals.array2D is a 1D array formaly, but its elements are 1D arrays too. That is why you get a 2D array
Hope that helps,
Max
(7,808 Views)
Hi
1- Concatenate two arrays to a One Dimensional Array with the += Operator
         (Locals.Combined2D += Parameters.Independant) += Parameters.Dependant
2- Re-Shape the result to a Two Dimensional Array using the length of one of the original Arrays as Parameter
         Locals.Combined2D.Type.ArrayDimensions.SetBounds ( { 0 , 0 } , {Parameters.Independant.GetNumElements() - 1 , 1} )
(4,487 Views)
this sequence contains an error:
Expressions must evaluate to a value of the expected type
(3,225 Views)
