NI TestStand
How to assign a configuration entry point local to a sequence local
Hi. I have a custom Process Model that has some custom Configuration Entry Points in which i write and read some locals. What i need to do is, when i execute the configuration entry points, for this variables to be assigned to a sequence files variabile. How can i do it?
thank you
(1,654 Views)
@domcorrado wrote:
[... ]to be assigned to a sequence files variabile. How can i do it?
thank you
Which sequence file are you referring to?
(1,629 Views)
