NI TestStand
How to automate lambda power supply
Can anyone help me how to automate lambda powersupply..Using the lambda drivers vi I've configure to control powersupply programed by setting different voltage levels and current limits at regular interval by changing input variable... Now I have to automate this system to automatically set the pre programmed values and perform the operation.
(3,127 Views)
Naveen,
You will need to use Action step of Teststand using the labview adapter.You can refer the help or the examples to find out how to call VI from TestStand.
(3,112 Views)
