10-11-2011 03:36 PM
Could you verify that there is a space between the two strings(one for the executable, and one for the argument)? I can't tell from the dialog.
Jim
10-11-2011 03:51 PM
I did not have a space, I added a space. Here is the block diagram and the error:
10-11-2011 03:54 PM
I am thinking...can I run that code by itself? Should I put that code inside the Simple UI?
10-11-2011 04:02 PM
It should work stand alone just like it was typed into a DOS prompt. Try typing the command into a DOS prompt and check that this works. Also - just a shot in the dark but sometimes the 'full memory' error can be fixed by a reboot.
Jim
10-12-2011 01:38 AM
This works for me
10-12-2011 10:28 AM
Guys, many thanks. I have found another way that doesn't require me to alter the code for every new sequence added to the file. I have it working with a few warnings about releasing the sequences when I'm done. I will still experiment with the command prompt thing but I think something more like this is what I'll need to do to keep the versatility.
I open the files as the UI opens, then I close the files before I exit the TestStand and LabView.
10-12-2011 12:58 PM
I figured out the last of the warnings...Instead of releasing the sequences and engine in the sub-vi I have to release it in the main vi. After that everything works great!
Thanks for all your suggestions and help.
Daniel
