NI TestStand
How to automatically load function parameters when editing c/c++ DLL call?
I built a DLL in CVI and is used in TestStand, I want this DLL to have the ability to automatically load function parameters after specifying Module pathname and function name in "Edit C/C++ DLL Call" dialog? How can I do it?
(3,553 Views)
You must have a type library for your DLL to load the parameters automatically.  This can be found in the Configuration >>Target Settings >> Type Library
If you are using a CVI based DLL, you can also use the LabWindows/CVI Adapter for additional debugging capabilities.
Allen P.
NI
(3,545 Views)
Staring with CVI 7.1 and TestStand 3.1 you do not need a type library for TestStand to load parameters automatically. Just make sure you declare your exported functions with the __declspec(dllexport) modifier as in the following code:
__declspec(dllexport) void fun(void)
(3,529 Views)
