NI TestStand
How to call a CString array from TestStand
I have a C++ DLL that uses a CString array, CString myString[ ],  that I need to pass back to TestStand 4.0 for inclusion in my results database.
In the TestStand module definition the parameter argument Description comes up as a CStriing pointer (CString*) instead of a CStringArray.
When I put my array of strings into the Value Expression I get an error: Expected String, found Array of Strings.
I have no trouble passing just a string pointer but that's not working either.
Can someone help?
Steve S
(4,935 Views)
Hi Steve,
I don't think that you can pass a CString Array from C++ DLL to TestStand 4.0 directly.
But you can do it another way: concatenate
all Strings by a delimit in your CString Array to build a new String,  then pass it to TestStand. In TestStand you can separate those Strings by the delimit, and rebuild a String Array.
For example:
// If this is your CString Array.
CString myString[] = {"AAA", "BBB", "CCC"};
// Build a  new String in your C++, and pass it to TestStand.
char  *myNewString = "AAA~BBB~CCC";
// Separate myNewString and build an Array in TestStand...
Hope that can help you!
Message Edited by My NI on 11-29-2007 11:34 AM
Regards
MY
(4,910 Views)
Hi MY,
No problem generating and passing a single CString.
I haven't tried to generate this code yet but I'm guessing I might do the following to seperate the strings and rebuild my array in TestStand:
1. Use the Len() function to get the overall string length.
2. Use the Find() function in a loop to determine the index of the delimiting characters. Pobably hold the indexes in a local array.
3. Use the Mid() function in another loop to retrieve the desired strings and write them to the new array.
Am I on the right track or am I driving off into the weeds?
Thanks for the help
Steve S
(4,901 Views)
Hi Steve,
Why not use CStringArray in your C++ code and then specify CStringArray on the parameter type?
(4,892 Views)
Sorry Steve, I have misunderstand your question. What I mean is the Return Value of C++ DLL, which is limited to type "Void", "Numeric", or "Boolean". You can pass Array of Strings as DLL parameter to TestStand directly.
Regards
MY
(4,885 Views)
The CStringArray class worked fine, of course.:Smiley Happy
Thanks very much to you both,
Steve S
(4,873 Views)
