NI TestStand
How to call a variable named "PI"
I have a typedef that contains a variable named "PI" like the constant 3.1416... but it's an acronym for "Program Information".... I can't rename it since it's a corporate typedef...
If I need to call it from an expression, TestStand takes it as the constant, but returns a syntax error due to variable notation... example "Step.Result.PI"
Is there a way to call it?
Jim
(3,667 Views)
This type def called PI, you dont say what is made of, lets say its just a string containing information about your program. To use it you would insert it as a Local, FileGlobal, Parameter or StationGlobal in your Sequence/SequenceFile/Station Globals.
eg Insert into Locals of MainSequence, Locals.my_pi (this is avariable of type PI) and you would enter some inital value.
How this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,663 Views)
Accepted by topic author JICH
Finally we found a solution,
Locals.PI_Get = ThisContext.AsPropertyObject.GetValNumber("Step.Result.PI",0)
(3,661 Views)
Jim -
Just to let you know that we are aware of this and we have an open issue, 131253, on this limitation.
Scott Richardson
https://testeract.com
(3,633 Views)
Hi Scott,
do you mean http://forums.ni.com/ni/board/message?board.id=330&thread.id=131253 ?
because it doesn't seem to work.
(3,608 Views)
What Scott means is that you can call in to NI Support to find out the status using that ID or check the readme for a release to see if that ID was fixed.
With warm regards,
David D.
(3,587 Views)
