NI TestStand
How to change button names linked with the 'connect command?'
I have linked a button in the sequence view to the Exeution entry point 2 (Single Pass) using the 'Connect command'. The button now displays 'Single Pass' as its caption name while running. I want to give a custom name to this button, but it should still be connected to the single pass function. How can rename it?
Regards
Gopal
(3,008 Views)
You will find the Text for the buttons in one of the ini files. Use the CustomStrings.ini to define your new text, which will override the text defined in the other ini file located in the NI folder when the Operator Interface or SeqEditor first launched and loads the various resources.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,002 Views)
