NI TestStand
How to change the sequence file version?
How to modify the sequence file version?
I am a new learner for teststand.
In the sequence file property , the software default version  is 0.0.0.0.
Is it possible to change it  from 0.0.0.0 to 1.0.0.0. just use an expression?
(3,641 Views)
Accepted by topic author open28
Hi Open28,
Yes It's possible to do it by an expression. But I like write TS API by LabVIEW method, it's easier to write for me.
@ LabVIEW method
@ Expression method  (RunState.SequenceFile.AsPropertyObjectFile.Version = "6.5.5.5")
Ricky
(3,627 Views)
Hi,ricky
Thank you!
(3,600 Views)
