NI TestStand
How to check any directory existance in TestStand?
Is there TestStand function? Or other option without writing my own code in external program (e.g. LabVIEW or C)?
Thanks in advance
(3,489 Views)
Accepted by topic author Berezka
Try the method Engine.FindPath. BTW many times when you are doing file I/O, depending on what you are doing exactly, you need to write a code module.
cc
(3,479 Views)
At Least according to the NI TestStand 2012 documentation, Engine.FindPath and Engine.FindFile work only within the NI TestStand SearchDirectories.
Maybe related: remote paths (\\server\path\to\file.ext) are considered "invalid" by Engine.FindPath.
(3,211 Views)
