NI TestStand
How to check whether array with string is empty or not
From the TestStand help:
GetNumSubProperties Method
Syntax
PropertyObject.GetNumSubProperties ( lookupString)
Return Value
Long
Number of subproperties within the property specified by lookupString.
Purpose
Returns the number of subproperties directly within the property the lookupString parameter specifies.
Parameters
lookupString As String
[In] Pass an empty string to denote the PropertyObject to which the method applies, or pass the name of a subproperty within the PropertyObject. Refer to Lookup Strings for more information about the strings you can use.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 11 of 14
(1,785 Views)
This is not working, and it is from the test stand help.
 Locals.BarcodeLengthAct   =  GetNumElement (Locals.BarcodeStrings[0]
Message 12 of 14
(1,709 Views)
fullmanido,
Try this instead:
Locals.BarcodeLengthAct   =  GetNumElements (Locals.BarcodeStrings[0])
I changed "GetNumElement" to "GetNumElements" and closed the parenthesis. I believe this will work properly. Let us know if you run into any more trouble with it!
Message 13 of 14
(1,707 Views)
If the array you want the size of is Locals.BarcodeStrings you should use this instead:
Locals.BarcodeLengthAct   =  GetNumElements (Locals.BarcodeStrings)
Not sure why you had [0] in there. That doesn't make sense unless you have an array of arrays and you want the size of the first array in an array of arrays.
-Doug
Message 14 of 14
(1,688 Views)
