NI TestStand
How to close a Remote engine session
Using the remote engine I notice that on server machine (where remote engine runs) it is possible to know if is a remote session and also retrieve the master engine reference.
Viceversa from an host (where runs a TS engine that calls the sequence remotelly) isn't possible to have a reference to the remote engine. It is true? There is a way to obtain such reference?
The primary scope is to shutdown programmatically the remote engine from host, cause we find that the remote engine closes only when the calling TS engine (on host) is closed.
The only way we found at present is to "brutely" kill the remote process.
There is a better way to do that?
Regards
Luigi Magni (System Engineer - CTA)
Message 1 of 1
(3,632 Views)
