NI TestStand
How to continuously record signals
I know that using a for loop can record, but when using a for loop, I cannot perform other testing steps. For example, I want to keep recording a certain signal, and when recording this signal, I can perform other testing steps. However, when the signal exceeds a certain range, I stop testing.
(796 Views)
You can configure the code module to run asynchronously. Use Termination Monitor to capture any possible termination from TestStand.
Run VI Asynchronously in TestStand
Asynchronously Starting and Stopping a VI in TestStand
https://tmesystems.net/
(772 Views)
