NI TestStand
How to convert a TestStand sequence into an .exe format?
How can I covert a teststand sequecne into an .exe format?
Shruti
(5,826 Views)
You can't. The operator interface, of course, can be an exe.
(5,819 Views)
Shruti,
As Dennis said, you cannot directly make a .seq file into an executable, but you can execute it with an operator interface (several examples are provided with TestStand). Additionally, you can configure the interface to automatically run a sequence when it is opened, as described in this KnowledgeBase article.
(5,813 Views)
You can also create an installer to deploy your system using the deployment utility.
-Doug
(5,806 Views)
