NI TestStand
How to convert an integer to a sting in an expression
HI,
I need the convert and integer to a sting in the following example
In the post expression:
Step.Result.ReportText = "This is channel No. " + Local.ChNo
I get an error of unmatched type. (Local.ChNo is integer)
CAn you show me how to convert the integer to string in this example?
Rafi
(3,132 Views)
Hi Rafi,
Step.Result.ReportText = "This is channel No. " + Str(Local.ChNo)
or you can format the string Str(Local.ChNo, "%x")
Check out the help within the function browser.
Regards
Ray Farmer
Regards
Ray Farmer
(3,130 Views)
