NI TestStand
How to convert code from a TestStand development license to a deployment license?
Looking to switch over TestStand code with a development license to a deployment license.
So far the code has only worked on a development license, and when we try a deployment license it does not work. Any ideas on why this would be? Is it a screwup in how we have setup the deployment license/teststand on our production computer? I don't have any experience in creating a test sequence for a deployment license. Thanks.
(1,647 Views)
Can you give a little more detail on what isn't working?  For example, is it not finding code modules?  If so, make sure your search directories are set up correctly.  Are you just trying to run a sequence or are you trying to do something else?
(1,590 Views)
I am still investigating the why, as I'm not the owner of the code, but I did have this error message sent to me if it helps-
(1,582 Views)
My guess is that you need to set the LabVIEW adapter to runtime instead of development.
(1,576 Views)
great job.. i found it very beneficial for me.. locksmith bixby
(1,541 Views)
