NI TestStand
How to create Master Sequence File w/ Error handling/Seperate Reports
I am writing automated Software Tests. I have Tests such as TCS-179-01, TCS-184-01 and so on that will be rapped up into a MASTER test. Here are my problems.
-I would like seperate reports for each of my TCS-XXX-XX.
-If an error occurs in TCS-XXX-XX, I would like it to run clean-up in the TCS-XXX-XX and continue onto the new TCS-XXX-XX. The step result for this sequence should then say "ERROR" as appose to PASS or FAIL.
-How do I controll weither the "UUT Serial Number" dialog box appears or the "Pass/Fail" Dialog box appears?
Thanks for the help,
Pat
(3,428 Views)
Hi Pat,
I think this threads will slove your task,
http://forums.ni.com/ni/board/message?board.id=330&message.id=22384&query.id=299009#M22384
http://forums.ni.com/ni/board/message?board.id=330&message.id=19908&query.id=296414#M19908
greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,418 Views)
Hi Pat,
I had some time to write a small example
just try it
Juergen
--Signature--
(3,413 Views)
