NI TestStand
How to create a Code Module with Access to the TestStand API in LabVIEW
From the website
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x11cCAA&l=de-DE
í get this
But i dont understand this since I am a beginner to Teststand.
This is my teststand UI of the current sequence I created
I want a labview program that can run this sequence and then access the final value. I dont know how to do that, that is why I am researching. I did this thing where I put an action step at the end. But then in the UI it is different from the website above.
But still there was a create VI here. So i clicked on that, and it was asking for me to select a VI. So i just created a blank VI and selected it here. And then I created the code using the sequence local and ran it  and immediately I am getting error code 97, Unknown System Error in Get USB Voltage_Blank.vi. So whatever I have done till now is completely wrong. This is the VI
I will also upload the VI and other files. Kindly help me in understanding the problem and correcting it.
(276 Views)
If you want to run your TestStand Sequence which calls a LabVIEW Code module from LabVIEW, Iguess you want to do so to implement a User Interface, don't you
In this case, you should look at the concept of operator interfaces e.g.
https://www.ni.com/de/support/documentation/supplemental/08/teststand-user-interface-development-bes...
or
https://share.google/YNS8KKcoJaUgNHSsy
If that's not what you want to achieve, please define what you want to achieve, so we can figure out how to do it
(266 Views)
