NI TestStand
How to create a lookup to a specific location
Hello everybody,
i'm trying to create a lookup string pointing to the current step. I tried the PropertyObject.GetLocation(topObject), but didn't succeed. It seems, i can pass whatever i want as topObject, the result stays the same: "Main[0]", which is right when viewing from "Sequence".
There's never an error. But i wanted a more global string as e.g. "RunState.SequenceFile.Data.Seq[0].Main[0]".
I'm using TS 3.5 and CVI8.01.
Any ideas?
Thomas
(2,962 Views)
hello thomas,
i am not sure, if i understood that right. i created a sequence, which points to the current step via the RunState property and prints the ID of this step in the message box.
i hope this help,
regards,
robert h
NI germany
(2,937 Views)
Hello Robert,
thanks for your effort, but this was not, what i'm looking for.
I needed to split a test step into 2. But i need to share some information, what i did with a global variable. This works fine so far. But i wanted to display to the user the location (lookup string) to the other step. The function PropertyObject.GetLocation ( topObject) should do exactly that. But i can't get it working. I can play around the topObject without any change in the result string.
Do you know, how to use this function? I attached a small example.
Regards
Thomas
(2,926 Views)
