NI TestStand
How to create a timer?
is there something in teststand to measure the time between two steps?
So that en testplan looks like this
Mainsequence:
step: "Timer start"
step: execute a teststep
step: "Time elapsed" (<-- returns time since the "timer start"
is there already something in TS or do i have to create new steps in LV to do this?
(5,706 Views)
Accepted by topic author OnlyOne
Attached is an example.  Just use a local variable and set it equal to Seconds() (you can read about that function in the help).
OR
If you need to watch the timer then you can spawn a new thread by calling a sequence with a VI that pops up and shows the timer.
Good Luck!
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,703 Views)
