NI TestStand
How to create data type programatically
we are writing a custom sequence editor that will generate TestStand sequence. I can populate the generated TS sequence sequence with steps using primitive arguments like Boolean, String, Number. Our test methods also use structures and I am having problem with programatically creating custom data type that matches C# struct similarly as one would do in SeqEdit.exe
I am assuming that there is something to do with Engine.NewDataType() and create new container, but then where to add the returned PropertyObject for it to be a type in the current sequence with a name?
Roman
(4,099 Views)
You can try this example, http://zone.ni.com/devzone/cda/epd/p/id/3606
I know its a version 2.01 but it should still apply.
There is a CVI version and probably a labVIEW version on the NI website.
Regards
Ray Farmer
Regards
Ray Farmer
(4,093 Views)
Ray, that's great. This pointed me to right direction, thank you!
In case someone else needs this; The example worked fine from TestStand, but not from C# :
 PropertyObjectFile[] typeFiles = MyEngine.GetTypePaletteFileList();
 PropertyObjectFile typeFile = typeFiles[0];
 TypeUsageList typeList = typeFile.TypeUsageList;
 string whyNotValid = typeList.ValidateNewTypeName(name, false, out isValidName);
 if (!isValidName)
  return null;
 PropertyObject newType = MyEngine.NewPropertyObject(PropertyValueTypes.PropValType_Container, false, "", 0);
 newType.NewSubProperty("MyNum", PropertyValueTypes.PropValType_Number, false, "", 0);
 newType.SetValNumber("MyNum", 0, 123.0);
 newType.NewSubProperty("MyStr", PropertyValueTypes.PropValType_String, false, "", 0);
 newType.SetValString("MyStr", 0, "AA");
 newType.Name = name;
 typeList.InsertType(newType, 0, TypeCategories.TypeCategory_CustomDataTypes);
 typeFile.IncChangeCount();
 typeFile.SaveFileIfModified(false);
SetValNumber and SetValString threw an exception on non-existing sub-property so I added the red lines.
There is one feature not mentioned in example - If you want to have the type in the sequence file instead of INI type files, it also works like this
 PropertyObjectFile typeFile = MySequenceFile as PropertyObjectFile;
(4,077 Views)
That's great, thanks for the feedback
Regards
Ray Farmer
Regards
Ray Farmer
(4,072 Views)
