NI TestStand
How to create multi dut testplan where duts are executed sequencial
i want to create a multi dut dut testplan for 100 DUTs.
All DUTs have the same teststeps but different matrix switching.
And: The DUTs should not run parallel but one by one as the needed measurement hardware exists only once.
I i would do this with a Batch-Model then Teststand would open 100 execution windows when execution in Teststand.
But if i use the sequencemodel with a 100-loop then i have only one result file.
What do i have to do?
(1,659 Views)
Accepted by topic author OnlyOne
2 options:
Use the batch model and use a sequential synchronization section.  https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/batch-synchronization-step.h...
Use the sequential model and have a counter in the preUUT that when you reach 100 it will set the parameters.continuetesting flag to false.
How do you enter the serial/part numbers?  That might change which option you go with.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,624 Views)
