NI TestStand
How to create own shortcut key?
You could make a process model entry point that executes MainSequence in the client file and does nothing else. If you make it the first or second execution entry point it will have a hotkey by default or you can assign a different one if you don't like the default hotkeys for the first two entry points.
Hope this helps,
-Doug
Message 11 of 11
(782 Views)
