NI TestStand
How to deploy custom Step List Configurations?
Step List Configurations is accessible to user via right click menu in Sequence File and Execution panes. How to deploy the custom Step List Configuration what I have at my deployment computer? Next question, if the user will modify this menu, how do not overwright the local changes with a new version installation?
(3,604 Views)
skof,
To you copy your Step List Configurations to another PC you can find them stored in the layout_current.bin file found in C:\Documents and Settings\<windows username>\Local Settings\Application Data\National Instruments\TestStand X.X directory.  If you copy this file to the same location on another PC, or even on the same PC to a different user account, your Step List Configurations should carry over.
Since this file is stored in a directory that is different for each major version of TestStand, you shoulnd't have to worry about overwriting it if you install a new major version (4.2 over 4.1). I haven't tested for minor revisions that would share a folder (4.0 & 4.0.1) but that would be the only situation in which you might need to be concerned.
John B.
(3,554 Views)
