NI TestStand
How to detect first Enter keypress in reloaded VI
Hi.
I'm using popup information VI's in TestStand which I want the user to be able to exit/confirm by using Enter/Return, and I'm using a Key Down event in an event structure to detect they keypress.
But the problem is that when the VI is already loaded in TestStand, the event structure doesn't detect the first Enter/Return keypress.  If I detect the spacebar, it works fine.  But Enter/Return always needs a first keypress before being detected as a Key Down event.
Anybody know why this is?
Best Regards,
Øystein.
(4,192 Views)
Accepted by topic author ojohnsen79
Do you have the Set to focus on toggle checked in the button properties.
See the attachment.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,186 Views)
Your suggestion worked like a charm.  Thanks! 🙂
Øystein.
(4,129 Views)
