NI TestStand
How to determine Thread, Execution for PostUIMessage
Greetings:
I am trying to develop a TestStand application with two User Interfaces (in addition to the Sequence Editor), and I need to be able to post UI messages back and forth between the two UIs.
So far, I have successfully created one UI, and I can post UI messages from a TestStand sequence to my UI. great.  I passed the Application Manager reference in the constructor to the UI object.
Now, I want a button on my first UI to cause a UI message to be sent to my second UI ... The PostUIMessage options I have are Engine.PostUIMessage or Thread.PostUIMessage ...   in both cases I need the thread, which I don't believe I have unless I pass it explicitly in the constructor.  Ideally, I would like to pass only one object in the constructor (to keep things simple).
I have tried creating versions of my first UI that pass the Engine reference, or the SequenceContext reference, but I seem to be unable to  extract the info I need from these.  For instance, from the SeqContext, in theory I can get the Engine and the Thread, but when I try to get the AppMgr reference from the engine
                TsEngine = seqContext.Engine;
                AppMgr = (ApplicationMgrClass) TsEngine.GetInternalOption(InternalOptions.InternalOption_ApplicationManager);
I get the following exception:
The instance of the .NET class could not be retrieved.
Unable to cast COM object of type 'System.__ComObject' to class type 'NationalInstruments.TestStand.Interop.UI.ApplicationMgrClass'. COM components that enter the CLR and do not support IProvideClassInfo or that do not have any interop assembly registered will be wrapped in the __ComObject type. Instances of this type cannot be cast to any other class; however they can be cast to interfaces as long as the underlying COM component supports QueryInterface calls for the IID of the interface.
Source:  SidecarLib   at
Do I really have to pass the app manager reference and sequence context and the thread as separate arguments to my constructor, or have I missed something that is causing the exception above?
Many Thanks,
Tom MacLean
(3,970 Views)
Accepted by topic author LabCat
It seems I have found the problem.
The example code that I based on my UI is from the article "Launching a Floating .NET Form in TestStand".  In this example, the Application Manager reference is in a class member defined as:
        ApplicationMgrClass AppMgr;
If you try getting the Application manager reference from the engine like this:
AppMgr = (ApplicationMgrClass) seqContext.Engine.GetInternalOption(InternalOptions.InternalOption_ApplicationManager);
thats when the exception mentioned above is generated.   If however the Application manager reference is defined as:
ApplicationMgr AppMgr;
and it is extracted from the sequence context like this:
AppMgr = (ApplicationMgr) seqContext.Engine.GetInternalOption(InternalOptions.InternalOption_ApplicationManager);
everything works as I had intended (with no exception).
I hope this can save someone else some grief.
Cheers,
Tom MacLean
(3,967 Views)
Thanks a lot for your explaination,
Works well now.
(3,330 Views)
