Thank you, but we have this problem,
there were already many sequence files, so
step B, may be a little bit tedious. But can you send me an example of this method ?
Secondly, there were two users,
1. the developer, who like to run the sequence using
Sequence editor, and enable this report generation option.
2. the Operator, that runs a custom Labview Operator Interface, which should not know about this option (since the Operator is expected to know little about test stand, just select the sequence and click runs), so the Operator Interface has to disable this options.
The problem comes one the developer runs it, and the next time the Operator try to run it, and the TestStand Sequence Editor has been modified by the developer.
Thus We want to mak
e sure that when the Operator run the sequence vi Operator Interface, the report generation option has been disabled.
