NI TestStand
How to disable "Terminate" button in Teststand operator interface?
I'm using default Full Feature Operator interface for the TestStand deployment (steps are in LabView).
But I don't want the operator has an option to terminate the test after he/she starts the test (after pressed "Test UUTs").
How can i disable that button?
(3,292 Views)
Hi Armitakh,
 I open the default Full Feature Operator interface and see how it run. The "Terminate" button will appear until a person press button of "Test UUTs" and disappear when the program is finished. So I think the easiest way to do is move Terminate button away form the windows.
 Or you just want to disable it in the period of execution, you can use callback function (Start execution and End execution) to make it temporarily disable.
Ricky
(3,249 Views)
Another option is to remove the privilege from the Operator in the users.ini file.  Then they can't click on it.  Also, this way you don't have to edit the UI at all.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,237 Views)
Thanks Jigg for the help.
So should i change Terminate to "True"(below image), because currently it was false and showed the "Terminate" button
(3,204 Views)
Hello Armitakh
Change the value for Terminate from True to False.
(Groups → Privileges → Operate → Terminate)
Chris
(3,184 Views)
@Chris_Märki wrote:
Hello Armitakh
Chris
This will change it for all operators.  Which if you want then go this route.  If you want to just change it for a single person then remove them from the operator group and set the individual privileges as desired.
jigg
CTA, CLA
testeract.com
(3,176 Views)
