NI TestStand
How to display the Failure Message in Status message box under parallel test model
I have a question about the failure message display. I found the error information will be shown in the status message box in the UUT information child panel if there is a run-time error. So I want to know how to transfer the failure message to status message box if the mainsequence failed. Actually I tried to changed all failure items into runtime error. And the failure items can be shown in the status message box. Due to this change. We found all of loop setting is disabled because we set the "on runtime error to run cleanup".
My question, Due to my customer operator interface have no execution view window, Is there a way to display the failure items in the status message box? Any modification about the 'modelsupport2.dll'? Any suggestions will be appreciated!
Thanks in advance
Corey Chen
Test Developer from OPPO
Message 1 of 1
(3,633 Views)
