NI TestStand
How to dynamic change Step Name?
I have a step inside For Loop. I would like that step have different name related to loop Number. how do I do it?
For example
In Test stand,
for i=0; i++;i<10
stepnamei
end
So in this way, If the step fail, I could know on which loop it fails.
Please advise on it.
(4,197 Views)
(4,191 Views)
Thanks Ray,
I tried the first method from your example. It works pretty well.
(4,183 Views)
the link no longer works.
can someone please let me know how to add the loop index to the stepname
(3,644 Views)
Hello NikolajEgeskovOstergaard, I am uploading a .seq file in which I can change dynamically the step name during execution.
In this example I just created a local variable called "Counter".
My sequence is just a fixed For Loop of 10 iterations.
And in my step Message Popup (the one I want to change step name dynamically), in Properties -> Expressions -> Pre-Expression I wrote:
Step.Name = "Step Name # "+Str(Locals.Counter)
Image3.pngThe result during execution:
I hope this example help you.
(3,621 Views)
