NI TestStand
How to dynamically load and execute a testplan from model
how can i add a teststep in SequenceFileLoad of the model that opens and executes a testplan?
Not like a subsequence, but identically to a normal file+ open + start testplan?
Thx
(1,554 Views)
https://zone.ni.com/reference/en-XX/help/370052AA-01/tsapiref/reftopics/engine_newexecution_m/
Just call that method.  It should work.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,512 Views)
One other thing I would mention:  It might be good to run it in a new execution.  It sounds odd but basically it won't lock up your process model by doing this.
jigg
CTA, CLA
testeract.com
(1,510 Views)
Is there also a command to only "load" a sequence and afterwards executet this then already loaded sequencs?
Thx
(1,470 Views)
You can use the Engine.GetSequenceFileEx to load a sequence file into memory.
Maybe it would help to understand your ultimate goal?
jigg
CTA, CLA
testeract.com
(1,458 Views)
