NI TestStand
How to enable Step Properties
I'm trying to implement Step Properties editor in my custom OI
by using TSUI_CommandsInsertKind (cmds, &errorInfo, TSUIConst_CommandKind_Edit_StepProperties, gMainWindow.sequenceFileViewMgr, -1, "", "", NULL).
Unfortunately the Properties popup  appears with all options disabled.
What is the way to resolve this problem?
(4,023 Views)
Hi YG,
What language are you writing your OI in?
(3,998 Views)
CVI 8.5 and TS 4.1
BR,
YG
(3,996 Views)
Do you have a TestStand user logged in with the correct privileges? If you aren't using user privileges you can disable them with a station option.
-Doug
(3,990 Views)
I've logged as administrator. Please find attachments in order to understand what I mean
YG
(3,987 Views)
Is your OI in editor mode? See ApplicationMgr.IsEditor.
(3,981 Views)
Thanks a lot, James. It's work.
(3,978 Views)
