NI TestStand
How to find a vi path in vi.lib?
Does anyone know how I can find a VI in vi.lib for a TestStand step?
I want to call the "Spreadsheet String to Array" VI from a TestStand step.
But how do I find out where it is?
How about a context menu on the block diagram which tells the exact path?
I've tried using "Find VIs on Disk" specifying "Spreadsheet*.vi", but it only
finds "Spreadsheet String to Digital.vi".
How about being able to drag a VI from a LabVIEW block diagram into the
LabVIEW step in TestStand?
Any ideas?
Ronnie
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
(3,656 Views)
It's not a VI and it's not in vi.lib, it's a LabVIEW primitive so you cannot call it directly in TestStand. You have to create a VI that calls it.
(3,644 Views)
OK - thanks. If it exists in a LabVIEW DLL somewhere, perhaps in the future it can be callable from TestStand.
(3,631 Views)
