05-27-2015 11:06 PM
usually where there is an error in the LabVIEW code module TestStand stops and gives a pouup message .
Is there any way to force TestStand to ignore LabVIEW errors and contiouse testing?
		11:10 PM
 - last edited on
		11-06-2024
		11:18 AM
 by
			Content Cleaner
Select the offending step.
Click on Run Options in the Properties tab
Check Ignore Run-Time Errors
OR
You could handle it in the SequenceFilePostStepRuntimeError callback: https://www.ni.com/docs/en-US/bundle/teststand/page/overriding-engine-callbacks-sequencefileposts.ht...
05-28-2015 10:10 AM
05-29-2015 07:24 AM
You can also work more globally - go to the Configure menu item and select Station Options.
At the bottom of the execution tab, there's a section for what to do on Run-time errors. -> Show dialog, Cleanup, Ignore or Abort.
Whilst not specific to steps configured to use the LabVIEW adapter (assuming you're mixing some programming languages) that at least get you continuing on to the next step without the dialog.
If you need to assess if it's specifically LabVIEW modules causing the error, then you need to use the Station, Process Model or Sequence File callback for On run-time error, and the step gets passed as a parameter. That would allow you to work out if the step was LabVIEW specifically and then make a decision as to what to do next.
Hope that helps.
06-27-2015 02:45 AM
Don't pass the error out (LabVIEW) to step.result.error (Teststand) so that TestStand Process model cannot get the error. popup will not appear.
I suggest to handle the error in a proper way.
I will be running another set of error handling code in TestStand on the cause of error, since ATE used to run days and nights, we cannot sit with the automation station to click the popup window :).
06-27-2015 02:50 AM
you can also design your own error popup window and place it in SequenceFilePostStepRuntimeError Callback design your error popup window that it has a timeout with it. after timeout it selectes ignore if now manual event on your custom popup has occured.
05-03-2018 03:16 AM
I know this tread is old and the answer won't be interesting to the thread starter any more.
But the tread will show up in search results of others...
Maybe the thread starter meanwhile also found that there is one more important thing that is wise to consider when one ignores errors:
If you ignore an error, then you are IGNORING the error ("ignoring" is not "solving").
Just imagine you are sitting in a twin-engine turboprop on it's way to your holiday insula and the plane just starts to fly over open waters.
The left engine starts to shake wildly and makes non-funny noises.
Would you really want the pilot to say: "Copilot - please silence these alarm horns and switch the red blinking lights off. I want to move on without such disturbance."
I guess not.
If he says the same about a failing inflight entertainment system you can live (and survive) much better with such an answer.
Selecting "ignore error", not connecting error clusters and alike is the same as if the pilot would switch off the warning system. He won't get ANY alert - be it harmless or grave.
If you ignore errors in your programs think first wheter you are shutting off the equivalent of only the inflight entertainment system status alert, the engine warning light or even the master caution.
