NI TestStand
How to generate a file with a step name and step unique id?
I want to generate a file listing the step name and unique id for each step in a sequence file.
I know I can display the step unique id and then copy it along with the step name, very tedious!
Any suggestions?
Any help is appreciated.
(2,568 Views)
This should get you started.  Let me know if you have any questions.
Cheers,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,538 Views)
thinking a little outside the box here: you could write and configure a custom TS Sequence Analyzer test that always generated an information result for every step.  Then save the sequence analyzer results as a xml document, which contains the UID of the step along with any other information.
(2,514 Views)
