NI TestStand
How to generate report for each UUT in the Test UUTs mode ?
In my current TS setup, if Single Pass (Ctl+F5) it test one UUT, it generate one html report and stop. If Test UUTs (F5), it will keep appending the result on same one html report until stop. How to setup/configure TS so it will generate report for each UUT in the Test UUTs mode?
I searched in configure-> result processing  and station option but cannot find it. Please help and thank you!
(664 Views)
Accepted by topic author BigDrum
You've been looking at the right place  😉
(639 Views)
That is exactly what I am looking for !
The reason I missed it because there is no that option when I am always thinking use "Specify Report File Path by Expression"🤣 but never try the other dropdown options
(628 Views)
