NI TestStand
How to get Error Message back before report generated with NationalInstruments.TestStand.Interop.API
I'm using NationalInstruments.TestStand.Interop.API in a VB.NET program and able to get back step results from ResultList as expected when sequence ran without error. When error happened, I could not get 'Error Message' (as shown in the image attached) back. Please shed night on how to get Error Message back before report generated.
Thanks a million!
(2,789 Views)
Hi!
Did you check this post, he is using the RunState.PreviousStep.Result.Error.Msg" to access the
errorMsg or error code.
Also, there is good documentation here: Ignoring Errors in TestStand
(2,757 Views)
Andr3s_Br3n3s
Thank you for your reply!
I tried to check out 'RunState.PreviousStep.Result.Error.Msg' but it did not work in my case, because I'm working on a plug-in which is called as the last step in the sequence to take all of the step results to insert into a database in our MES. Hence it is likely not the Error of PreviousStep.
We do not want to create a TestStand report while want to get Error information as in report generated (as in the image attached) before execution finished if possible.
Please continue help.
(2,743 Views)
Hi !
Maybe, you can call an engine callback, so you can call a certain sequence before and after the execution of individual steps, a post-step callback you could use, and check if there is an error. if there is an error do something if there is not keep running.
(2,721 Views)
