NI TestStand
How to get a edited string to be evaluated again
hello, I'm very new to TS and don't know if I express the problem clearly. however the question below:
I try to edit a numeric variable before it's evaluate at runtime and what i did is:
Val(SearchAndReplace("FileGlobals.I_LB_bin[FileGlobals.loop_BINi]","LB",FileGlobals.Mode[Locals.modei]))/2
but after the replacement seems the val function can get value with new string.
how can i get a string to represent a value and be evaluated again after edit?
thanks a lot!
(4,349 Views)
Accepted by topic author johnnnywang
I am assuming that you are trying to get  a variable expression evaluated at runtime. I would do the following
Locals.Num=Val(Evaluate(SearchAndReplace("Locals.Var_X","X",Locals.Control_Num)))
All the  variables are String and the output is a number on which you may perform further arithmetics.
You dodnt need the variable Locals.Var_X at all. I just created during my trials.
Ranjith
(4,331 Views)
