NI TestStand
How to get all step names within a group or a sequence?
I'd like to show all the names of the steps within a sequence or a group.
I wonder if there is a simple function which can be used directly, such as RunState.PreviousStep.Name.
I tried via a foolish way to append each step name, though it shows all the step names but I still think there is a simple function can access all the step names.
Can anyone give me some suggestion, thanks a lot!!!
(4,895 Views)
Accepted by topic author William1225
I've doctored up your sequence a little.  But yes you have to loop.
Also, what format do you want the names in?
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,864 Views)
Hi, Jigg,
Thanks to your reply.
You use a simple and compact form to work it out.
I still wonder if there is an API function can return all the step names in a form of array instead of loop.
What do you think?
(4,836 Views)
There is no way to do this without looping.  At least not in 2010 SP1.
Sorry.
jigg
CTA, CLA
testeract.com
(4,823 Views)
