NI TestStand
How to get back deleted Inbuild examples
I deleted examples at:
<TestStand Public>\Examples\
How can I get this examples all back? Where can i download them?
(2,583 Views)
Hi Skoda3,
i tried it with TestStand 2017. If you have the installer executable. You can extract the data by running the executable.
Then you will get a folder structure like that on your harddrive.
You can then navigate to the following subfolder (depending on your extraction path"
C:\National Instruments Downloads\TestStand\2017\Products\TestStand64_Examples_2017....
Here you can now run the "TSExamplesPart64.msi" installer which is responsible for coping the data to the user directory.
C:\Users\Public\Documents\National Instruments\TestStand 2017 (64-bit)\Examples
This restores the files if you have mistakenly deleted them.
Greetings from Austria
Andreas
(2,564 Views)
