NI TestStand
How to get rid of 'Watch Expressions'
Hi all,
I'm debugging my program using TestSTand 3.1 + CVI 7.1.
I've added some watch expressions using the 'Add Watch Expression'. It seems to slow down the execution and I wish to remove them all.
How do I do that?
Rafi
(4,392 Views)
Just highlight them and delete them. Not sure if they is a setting, or menu item to clear watched items. Dont recall seeing one.
Regards
Ray Farmer
Regards
Ray Farmer
(4,389 Views)
Rafi -
In the sequence editor, you can display the Edit Breakpoints/Watch Expressions dialog box by selecting "Edit>>Breakpoints/Watches...". You can then delete all watches.
Scott Richardson
https://testeract.com
(4,377 Views)
it seems there is no possible way to get rid of "watch expressions" on labwindows CVI 13 evaluation version:
You cannot highlite many watch expressions only one by one, which is long to erase when many
The Edit Menu doesn't offer "edit breakpoints/watch expression dialog box" and didn't find a "sequence editor menu"
thanks for help
Raph78
(3,909 Views)
Hey Raph,
You might want to post this question on the LabWindows/CVI forum. This forum thread is in reference to watch expressions in TestStand, which explains why some of the menus are not available in your software. The users over on the CVI board should have some suggestions for you to help solve this issue.
(3,903 Views)
