NI TestStand
How to get step properties without lookUp strings ( C# )
Hi
I have used TestStand 4.0 for a couple of weeks and the goal is to create a custom standalone tester. One question has arised: How to get custom step custom properties in code without knowing what to look for? Is it possible or does one always has to know that to look for.
BR,
Timo M
Message Edited by TMalm on 02-26-2008 06:08 AM
Message Edited by TMalm on 02-26-2008 06:16 AM
(3,102 Views)
If you are trying to iterate through an unknown property structure, then the following PropertyObject methods can be useful:
GetNumSubProperties
GetNthSubPropertyName
GetNthSubProperty
GetType
GetVal<DataType>
GetPropertyObject
For arrays, the following are also handy
GetNumElements and/or GetDimensions
GetVal<DataType>ByOffset
GetPropertyObjectByOffset
Note that even for arrays with multiple dimensions, you can iterate with a single loop thanks to the "ByOffset" methods. You can convert between a linearized offset and multidimensional coordinates with the GetArrayIndex and GetArrayOffset methods.
If you hit a road block, make sure you check all the available methods and properties of PropertyObject.
(3,086 Views)
